- September 23, 2020
- Location
- United States
- Alabama
- 99 Explorer XLT 4.0 SOHC
Cylinder 5 spark plug
upper and lower intake gaskets were replaced in NovemberHave you replaced your upper and lower intake gaskets
Your fuel trims are a bit off
Looks like a vacuum leak to me
Smoke test maybe
What's the cheapest way to do a smoke test?Have you replaced your upper and lower intake gaskets
Smoke test maybe
Nope I don't smoke
The first video is before the short drive
this video is after the drive
That's awesomeOne of my very good friends is from Huntsville Alabama
An old war vet
Hello guys I have a 99 explorer 4.0 SOHC that is having some weird idle issues it idles way too low like around 400 to 500 RPM and I have replaced the IAC Valve DPFE Sensor TPS sensor and cleaned the MAF I've also replaced the fuel pump and fuel filter along with the intake manifold gaskets
On my 96 I had a very subtle vacuum leak on the egr tube where it meets the intake. Mine's an ohv engine. You sound like you have 10 time the knowledge I do of how to test and read the computer diagnostics. Really. Impressive. Just saying I had very similar issues when I re-did my top end---that damn gasket, aftermarket gasket, etc that stops vacuum leak at egr tube to intake was crap. I finally got it right (with a little extra silicone or aircraft glue-can't remember) but that's where my leak was. I replaced everything you did too including fuel injectors (however my first amazon DPFE was crap and failed in 3 months-but it threw a code- unlike yours).No doubt -
I didn't know if it was your Ex or a customer's ride.
Yeah - $30 VS $7 - that's a no brainer in my book - given Stant has always worked for me.
That sound you hear is me knock on wood.
PS - Gates for hoses -
Link don't workI didn't know that a simple propane tool now cost $100+
Here is a long winded video on how to make your own.
www.youtube.com › watch
DIY Vacuum Leak Detector With Propane - YouTube
Using this tool and monitoring short term fuel trim is the best way to find even the smallest of leaks.
