'99 Ranger to '94 B4000 | Ford Explorer Forums
tripytrucker
va
94 B4000-99 Explorer
Will these two swap transmissions? Both have type "M" trans on the door frame but I saw in one of the stickys that they may be an r1 and r2 transmission.Are they compatible? Thanks
...This might answer your question...;)
Door code M = Mazda M50D-R1 5 speed
1988 & Up 4-Cylinder Rangers
1988-1992 2.9L 2WD Rangers
1991-2000 4.0L Ranger
1991 - Up 3.0L Ranger
...:scratch:...You might have been thinking of the M50d-r1HD
Door code J = Mazda M50D-R1HD
2001 & Up 4.0L SOHC Ranger
1997-2001 Up 4.0L SOHC Explorer
what you have to consider is the size of the engine. these 5 spd trannys have an integral bellhousing (non-removeable).
the B-4000 Mazda would have been a 4.0. if your 99 Ranger is a 4.0 engine, Okay.
if your 99 Ranger has a 3.9, 2.3 or 2.5........no go....won't fit because of the difference in the bellhousing bolt pattern.
J...lazing on a balmy Sunday afternoon.
OK Thanks guys... I hit the panic button there for a min.I had already bought the trans off the ranger and pulled it.
Thanks Again for the quick replies.
Tripy
