99 rear discs into a 94 | Ford Explorer Forums
cerberusaardvark
San Diego
1994 Explorer xlt
hey guys, i decided to do the 2nd gen rear axle swap into my 94. i had a couple questions though.. has anyone here done it? in the pic i noticed that the centersection is slightly offset to the passenger side. when i went under to check to see if mine was offset also i couldnt really tell. will this fit onto my driveshaft straight? also, will those leafs fit right into my 94 also? found a great deal on all this stuff, just need to make sure it fits!!!
heres the link to the listing.
http://cgi.ebay.com/ebaymotors/ws/e...10584604125&ssPageName=ADME:X:RTQ:MOTORS:1123
You could just find in a junk yard rear disc brakes from the bracket out instead of swapping axles, unless you are after a different gear ratio. Would save you money probably.
As far as I know it will fit, but there is no gain changing your axle to a newer one besides disc brakes, lower miles (maybe), and lower gear ratio (maybe). If it is a lower gear ratio then you have to figure something out to get the front ratio to match.
Yes it fits. I have a complete 1997 Rear-end under my `92.
Ryan
