STrac4me
- October 10, 2008
- Bonneau, South Carolina
- 2007 Sport Trac Limited
First the disclaimer.....I have no working knowledge of A/C Hi/Low pressures. All I know about A/C is the compressor should cycle and not short cycle.
Here is the problem.....The last couple of days here in SC has been in the mid 80's so I ran the A/C. The first day it was blowing slightly cool air, but not cold. I checked and the compressor will cycle on/off (not short). The next day I found the passanger side vents were delivering colder air than the drivers side. I checked the temperature between the sides and this was the results (A/C on max....RPM's at 2K):
Driver's side - 80 degree F.
Passanger side - 65 degree F.
Why would there be a 15 degree difference between sides?
When I start the A/C I hear the door close (I could only assume that is the blend door). I do not have any means of checking pressures until my buddy gets back in town on Monday. Any help would be appreciated.....Thanks
