johnvosh
- November 14, 2010
- Stony Plain, Alberta
- '93 Sport
So I decided it was time to get the A/C going in the Explorer. The bearings were completely gone in the compressor so it was bypassed. It is a good thing I checked things out before I went all crazy.
Decided to check the orifice tube to see if it was clean, but it wasn't. Basically the whole thing on the long side was covered in black and tiny metal flakes. Really sucks! So I decided to pull the whole A/C system since it would be hard to remove everything from it.
:thumbdwn:
The only thing left that I need to remove is the evap core and get a non-a/c blower box. Was checking out prices and to replace everything would be around $120 from pick-n-pull. The only problem with that is, how many have the black death and is it really worth it since you can't get good ole R12 anymore. And I am going to get some screen to put in front of the rad to protect it a bit since I took out the condenser.
What is the best and easiest way to remove the air box? Do I have to take apart the dash to remove any bolts or nuts?
