boggsie
- September 5, 2008
- '01 XLT Sport AWD
Well,
I've found all of the threads here to be a very good source for ideas and I appreciate all of the experts offering their opinions.
I have 2001 Ford Explorer XLT 5.0 w/ AWD - 147k miles.
On the way to work today, I felt a vibration or shudder, followed by a period of no cold air from the A/C vents. After a few minutes, cold air returned, but it also included what almost seemed like an electrical burning smell. At this point I still had very cold air, but I felt that turning off the A/C was a good idea.
When I got to work I pop-ed the hood and started the motor. Sure enough, a really bad grinding noise coming from the A/C clutch. If I turn the A/C on, the grinding goes away and I still get cold air. I am sold on the clutch being the culprit. Don't hesitate to offer an opinion otherwise.
It seems to me that I have three options.
1) Try to replace the clutch with the compressor on the car.
2) Remove the compressor and install a new one and take it to get evacuated and recharged.
3) Remove the compressor and install a bypass pulley.
4) Drop it off at the dealer and have them fix it.
Ok, I just did upper control arms, front wheel and rear (outer) axle bearings so money is extremely tight right now, which is why I throw in #3 ... go without A/C until I can get it fixed.
So, the biggest obstacle with #2 & #3 are that the system is still pushing really cold air, so it obviously still has refrigerant in the system. I understand that evacuating a pressurized system to open air is a) illegal and b) highly dangerous.
Well, that is my story.
What do you feel that I should do? Again, considering that $$ is _really_ tight right now.
Thanks!
Best regards,
-boggsie
Thanks!
Best regards,
-boggsie
