CiscoKid4
- May 11, 2019
- Memphis, TN
- 97 Mercury Mountaineer
You're a lifesaver Tbars!I was screwing with that thing for hours, and never would have figured that out.
Here is what I did:
- Installed clutch on shaft, and installed bolt loosely.
- Added spacer between outer clutch and field coil.
- Tightened bolt.
- After getting it as far as I could, I backed out the bolt, and added a second spacer to finish the job.
To install the pulley/bearing, I simply pushed on the left side with my hand, while tapping it with the ball-peen hammer on the right side. I placed a plastic spacer over the pulley so as not to mark it up with the hammer.
Next, I installed the snap ring, placed a little anti-seize on the outer clutch teeth and bolt, added a few washers, and tightened down the bolt. There was some blue stuff on the bolt I removed. I assumed this was some sort of anti-seize, so I did the same with the new bolt.
The torque spec on the bolt is pretty low, so I just snugged it up. There was no way to hold the out clutch in place (that I could see), as it was made differently that the original. The original had 3 "nubs" sticking out out of the front, which I could use for leverage with a screwdriver, when removing the bolt. Not sure how I was supposed to do it on the new one, but hopefully it's tight enough.
Cursed a bit as I installed the serpentine belt by myself, and started it up. Nice cold AC, as always (when it was running).
So, now the problem .....
Now the clutch cycles about every 2 seconds. Before replacing the clutch, once it was on, it stayed on, when the AC was running. I know it should cycle even when off, though not every two seconds, but this behavior seems odd.
Do you remember the width of the washers you used? I'm trying to install a new ac compressor coil as well using washers like you did, but the screw breaks from the pressure before the coil presses all the way on. And also did you use two sets of washers or three, I'm worried maybe I'm not applying even pressure around the coil maybe?
