VinnieBoombots
- June 29, 2008
- Southwest USA
- 1996 Limited (140K miles)
I recently left my 96 Limited in the driveway for about 6 weeks. Before the layover, the A/C was working great. I returned to find the A/C no longer putting out, on one of the hottest days of the year.
Reading this forum assisted me in diagnosing and fixing the problem. I thought that I would attempt to pay you folks back with a detailed description.
Symptoms:
1 - Hot air blowing out of vents (dead giveaway here)
2 - Compressor cycling about every six seconds as opposed to not working at all.
Video of Compressor -
I edited because I had the wrong video link
Many pointed out that if the unit was cycling it was probably low pressure (not enough refrigerant).
I elected to use the Arctic Freeze R-134a. I found this at Advanced Auto Parts in my area for $49.95 + tax. The instructions were very clear and easy to implement.
Never having done this before, I did open the wrong black cap in the engine compartment. I opened the high pressure cap - quickly noticed because the included gauge assembly did not fit on the valve.
Low Pressure side is located on the left side (looking at engine from front) toward the rear. See attached pic.
I took the preliminary reading without the can of R132a attached and it was low. Shake up the can, connected to the system, and proceeded to charge. For me the system only took a half can to charge to the recommended 38. It would not take any more.
As soon as I started to charge the system, the compressor resumed normal operation and continued to run steady. Disconnected the R132a and cleaned up.
The A/C unit is putting out icicles inside the truck. WooHoo!!! Success.
Hope this helps anyone who is faced with the same problem, and thanks to all of you who I read when I have a problem.
Symptoms:
