jddanks
- February 12, 2009
- west Yorkshire
Last week , my ac started acting up, it was working fine, then on wednesday i turned it on max ac, cold air came out of the dash vents ( the main ones that blow air on driver and passenger), but then it started switching from those vents to the defrost vent and back again every minute or so, then next day i turn on the ac and all i get is hot air, no matter what position i set the controls to (temp and vent controls) i looked on here and seen about the blend door probs, but they all seem to say that with that prob you do get cold air on max ac. any way next day i fiddled with the temp knob, and kinda pulled it as i turned it to cold and lo an beold cold came out, but again on max ac it started to switch from vent to defrost, i turned the setting to just plain ac and it stayed cold and kept comming from the dash vent..until next day ..then it came out hot, and wont change. anyway i seen on here it may be a vaccum hose come loose so i went looking, and heres where i may need Howards help once again, as he seems to be the vac expert on here. on mine theres two vac hoses come out from under the ac box on the bulkhead, and go along the bulkhead and head to the front of the car, the black one goes into the vac reservoir, as does another black one that comes from under the coil pack(i think it is joined to a red line from the manifold) but, there is also a grey pipe which follows the first black line from under the ac by the bulkhead, and runs alongside it all the was to the front, however this grey pipe ends right next to the front of the coolant bottle, at its end is a rubber connector thats obviously supposed to be connected somewhere, question is...where?? ive looked and looked and can see no place or pipe to connect it to..anyone any idea?? or even does anyone know just what its for?
hopeing yall can help
Dave
Dave
