Reaper01
- January 18, 2015
- Tennessee
- 1997 Ford Explorer 5.0 V8
AC gone, belt size for me
I finished gutting my Explorer's AC a little over 6 months ago. The magic number for my truck (Explorer 5.0 XLT AWD) was 83 1/4" (Masterpro #K060827 6K827) As far as removal I would recommend taking the 2 bolts out of your washer fluid/radiator reservoir and 1 bolt out of the cruise control module and set those out of the way. The Ranger may be set up the same way. Then its about 8-10 smaller bolts and you can pull the whole case right out with the fan, then separate the case and pull out the AC core. You don't have to mess with the heater core and I believe you can leave the heater hoses clamped to the firewall if you pull whole unit straight out. Once I bolted the whole unit back to the firewall I sprayed a little bit of can foam (Great Stuff®) around the inside of the holes the old AC lines ran through, let that set up and put some heavy duty black duct tape over the now plugged holes. I mentioned before about only having about 1/4" (not even that) between bottom of the idler pulley and top of the water pump pulley and I haven't had any issues with it. Removed alot of weight, gained a little power/MPG, heat seems to work better, created alot more room to work and made a little $ off my aluminum. Should have done it along time ago since the AC didn't work and I wouldn't use it if it did.
Also I have not removed my condenser yet. I cannot tilt my radiator back enough to squeeze condenser up and out because of my fan. I will have to drain and remove radiator so I'll do that later.
