merc80
- December 11, 2006
- Middle TN
- '95 XLT 2wd
My wife's '95 ex is having trouble with the a/c. It works normally for a while, sometimes over an hour. For example, last weekend she drove to Nashville to run some errands. The a/c worked fine on the ninety minute drove there. It worked during several short trips around town to different stores. On the way home it worked for about 10 minutes, then shut off until she was a couple miles from home, when it came back on again.
I checked the low side pressure the next day. It was about 25psi. One can of r134a later, it was about 45 psi. Ambient temp about 95F through all of this. After adding the r134, it was blowing a lot colder but she says it shut off again about half way home from work. I checked both high and low side pressures this time, low side still about 45psi, high side was about 300psi. According to the instructions that came with the gauge set, 45psi was slightly low for the ambient temp, and 300psi was at the very high end of the normal range. It's been between 90-100F around here for the last week or so.
I've spent several days searching old posts here, and it seems all posts with my symptoms lead back to the same thing, low freon. Should I try to add another 1/4-1/2 can? Any and all suggestions would be much appreciated.
