I would take that ST off your hands since it is such a pile
The cat can come too if too attached to the trac to give it up.
Would fit right in the shop with the 3 other sport tracs around here and the 3 other cats
I friggin love sport tracs
4 door ranger or sport trac, that IS the question
I like really the Sport Trac too. Great design, but... Right now the engine is in a million pieces and is ready for me to pull it out for head gaskets and timing chains. This truck is a POS not because of the way it looks, but because it's been
such a lemon and sooo unreliable. I bought it sight-unseen for $1000 w/180K on it, as a non-runner, 4.5 years ago and it's given me nothing but trouble since.
A list of stuff I've fixed over the past 4 years (and what needs to be fixed):
Replaced fuel pump and filter (made it a runner)
On first drive I found oil pressure zero at idle
Dropped lower oil pan and removed a inch of sludge, cleaned the clogged oil pickup screen
Replaced lower pan gasket
Replaced valve cover gaskets (found more sludge in left head)
After a month of driving it developed a front timing chain rattle
Installed the Ford 00M12 kit (no improvement) began pre-oiling engine w/starter motor
Installed intake O-rings
Replaced PCV valve
Flushed engine twice and replaced oil/filter multiple times
Replaced t-stat (twice, second time with a Motorcraft)
Replaced cracked windshield
Installed Bosch Evolution wiper blades
Put 4 new tires on it
Replaced cracked coolant/WS tank
Replaced hood struts (after hood broke my drop light)
Replaced the #3 cyl spark plug and wire (PO had replaced the other 5, breaking stuff)
Flushed cooling system
Replaced leaking radiator twice (second one warrantied)
Replaced hoses and serpentine belt
Replaced idler pulleys and belt tensioner
Put new brakes front and rear
Installed new upper/lower ball joints
Installed new front/rear sway bar links
Replaced worn driver's door upper hinge
Diagnosed window problems (only driver's window worked)
Replaced master window switch
Replaced mirror adjustment switch
Replaced every part in the left rear door except the latch (PO destroyed it)
Replace both rear interior door handles
Replaced body mount bushings with Prothane kit
Replaced battery tray (PO had sawed the front of the old one off to replace a headlight bulb)
Diagnosed why A/C didn't work and repaired (top broken off high pressure switch by PO)
Diagnosed why heat didn't work (bad blend door actuator and vac line off heater control valve)
Replaced transmission filter and fluid (fluid is still black)
Reverse band slips on hills (maybe a bad EPC solenoid) forward gears okay
Replaced the complete rear end assembly (every part in old one was trashed)
Replaced console lid (old one broken)
Replaced both cruise control switches (covers were totally gone)
Would like to replace sun-melted steering wheel
Repainted all silver trim in interior
Removed gauge cluster to clean out dust and dead bugs
Replaced all interior light bulbs and non-working HMSL
Replaced HVAC control panel (lights intermittent)
Added a white overlay on HVAC controls to match gauge cluster
Need to reupholster driver's seat with new foam
Had an axle break and lost a wheel at speed, destroyed brakes and backing plate
Replaced axle and other damaged parts
Replaced non working left front door lock actuator
Had 2 recalls performed
Cleaned an absolutely disgusting interior and P/U bed
Bought a used OE Sport Trac bed mat
Installed temporary front seat covers
Replaced cracked tail lights
Cleaned and detailed body and engine
Replaced torn-up front bumper cover
Fixed broken fog light bracket
Fixed bent-down rear bumper
Fixed non working key locks on cab and bed cover
Retrieved keypad code and replaced missing key fobs
Bought a spare OE RF key (still need to cut & program it)
Replaced missing rear bed cover lock retainer clip
Replaced missing rubber lock cover on bed cover
It could use new shocks F & R
It could use new front brake rotors,w/bearings and seals
Needs to have t-stat housing replaced (going with Simmons metal housing)
Needs a new battery
Needs a new oil pressure switch (sometimes sticks)
Need to straighten front tow hook mounts and weld/bolt them back to frame horns. if ever a vehicle needed tow hooks it's this one.
Maybe I should rebuilt the trans while the engines out???
When it's fixed I'm giving it to my daughter. Then it can be her problem
