WyattH
- November 9, 2011
- South Carolina
- 1998 Explorer XLT
Wondering you guys can help me out here
Problem #1
Spark plugs go bad commonly (Every 2 months or so) and give me a really rough idle,bad throttle response and rough engine around 1.5-2k rpms. From my knowledge this is misfiring and it will always be one or two plugs that randomly go bad. Slight smell of unburnt fuel aswell.
Problem #2
Power steering noise. I have plenty of fluid but it makes a fairly noticeable noise when i am braking and turning. Pump i assume?
Problem #3 (Cosmetic)
Steering wheel buttons are distentigrating quicky. What replacements can i use for this? Or good aftermarket parts for it. (preferably plastic. That gel stuff is a nono)
Center console is tearing apart. I saw a thread for suede but i have actual leather interior. Are there replacements for this?
Problem #4
Rear driverside door is incapable of being opened from the inside. Child safety locks arent on and its perfectly fine with being opened from the outside.
Passenger side door handle has to travel alot further to open and doesnt have the satisfying click my other door handles do.
Problem #5
Rear windshield wiper cant leave the notch its in by its own power. If i set it on the window it will work but cant close itself and makes a really awful grinding noise. Stripped gears?
Little info about the truck
1998 Explorer XLT (Leather interior)
4.0 SOHC v6
Auto transmission
Four door
Throwing a bad O2 sensor code. and possibly more. Ill have to get my uncle to hook it up and see what its doing sometime this weekend hopefully.
Fuel filter needs to be replaced but alas i don't have the tool to do it and im not sure what size it is. Apparently there are different size lines according to the autozone guy?
Otherwise underbody is rust free. All filters are fresh and new. Spark plug cables are new. and the exhaust has no unusual sound
Thanks for the help in advance. Anything else you guys need ill try and get it for you.
Problem #1
Problem #2
Problem #4
Problem #5
4.0 SOHC v6
Auto transmission
Four door
