ga_sport4X4
- August 14, 2001
- Atlanta
- '98 Sport
For the record, this is my first time fiddling with these parts on my X. I've looked around the boards and read the sections within the Hayne's manual, but I still have several questions for those of you that have the knowledge.
'98, 4x4, 4.10 limited slip, V6 SOHC
Universal questions:
1. Any specail tools required?
2. Is it absolutely necessary to have the car off the ground so I can spin the rear tires in order to re-align the marks I make on the driveshaft.
3. Should i buy a torque wrench to make sure the specified torque requirements are met? (Prolly a dumb question)
Slip Yoke:
1. Lithium grease right?
Rear pinion seal:
1. How much diff. fluid is going to leak out when i remove the seal.
2. Any way to measure the amount of diff. fluid?
3. A crush sleeve has been mentioned in a previous post and by the mechanic who flushed my tranny. What is it and should it be replaced as well?
Also, any tips you veterans wish to share on the above will be greatly appreciated.
Slip Yoke:
Rear pinion seal:
