Display Brightness
Well, this question is directed to all who had a console in their truck from the factory, or to those who have connected the dimmer switch wire if you installed it yourself.
I just recently finished installing an overhead console in my truck, but I did not connect the wires for the vehicle speed sensor or the dimmer switch. I was wondering if the console display is supposed to dim when you turn the parking lights on. On dark nights, the console display is so bright, it is almost distracting when I drive. Is it supposed to dim, cause if it is, then I will take the time to take the truck apart again to connect the dimmer switch wire. If it doesn't, then I'm not going to worry about it and just deal with it on dark roads.
If it is supposed to dim, then what wire on the dimmer switch am I supposed to connect it to. Thanks guys.
