Thanks for your input BB
I've carefully studied all the info on here, including links and have come to the conclusion that I must have a slightly distorted overdrive clutch ! (probable leak?)
This is the clutch that is being used for engine braking in 3,2 and 1 and is also used for reversing!
It doesn't help, that I only have two drive plates (factory) in it, unlike all the other A4lds that seem to use three drive plates!
I've also noticed that the 4.0 L uses six clutch packs instead of the five clutch packs.
Is this a worthwhile upgrade?
Over drive must be slipping because the the surface of the overdrive clutch hub was so smooth after machining, the band must be having trouble keeping a grip of it?
Is this possible?
Everyone likes pictures, as it makes things a lot clearer:
Here are the overdrive bands!
New at the top and the old overheated one underneath!
Either the band was slipping really badly, or the clutch pack was causing this heat damage!
What do you think?
The overdrive hub before machining
And after machining
Here's the original boost valve.
Was exactly the same size as the Sonnax large boost valve that has gone in!(802/463-9722) The O ring seals are defo. a good idea!
On this picture, you may just notice/work out it only has two clutch plates
I will be rebuilding the original box in the near future and intend on upgrading the overdrive clutch pack!
Can anybody think of any possible side effects, if I fit three clutches for the overdrive ?
Why would Ford only give me two?
And anybody tried the Kevlar bands? do they grip like a rottweiler ?
