kdhsava
- September 21, 2006
- Roseville, Calif.
- 87 bronco 2 4wd
when i take off in d or od it wont shift out of 1st unless i move shifter to 2. then it wont shift to d or od until i hit 3500 rpm or 35-40 mph. this is when its cold.
Then once its warmed up it works fine. upshifts and downshifts perfect. but then after about 15-20 min. of driving when im coming to a stop it acts like it would if i had a clutch and came to a stop and didnt push in the clutch, and it will stall unless i manually shift down to 2 or 1 then it will click into its nuetral mode. can anyone help with ideas of what might be wrong?
its an 87 bronco 2 2.9 auto 4wd.
changed fluid and filter and modulator
