natenkiki2004
Blue Bomb!
- November 3, 2013
- Location
- North Idaho
- 1991 & 1994 Explorers
I decided to get some more info and shoot a video of the symptoms that my 1994 Explorer has. I bought it as non-running and I'm happy with the investment but I figured I'd try a few easy things to get the transmission shifting again. I haven't changed the fluid but it did dump out at 2-3 quarts on the ride home (previous owner removed the vacuum modulator, I installed a new one). Because of that, I poured a bottle of Seafoam TransTune in and filled the rest with Valvoline MaxLife ATF. I also installed a Magenefine filter before the auxiliary cooler. I've only been able to drive it about 15-20 miles (no plates, severe front end suspension issues) and nothing's changed.
Here's the video I shot earlier today:
https://www.youtube.com/watch?v=K8cdHZDV5JA
What I thought at the time is that no matter what, it stays in first gear until up to 30MPH or so and if you rev the engine up to 4,000 RPM and drop off the throttle, it may or may not go into the next gear. Sometimes you can hold light throttle and it will stay in that gear and then just fall out into 1st again, randomly.
While editing the video, I'm wondering now if I'm just missing 2nd gear and the trans is behaving normally? Winding up first then hitting 3rd and kicking back down due to inadequate vehicle speed. I'm not entirely sure. I never feel a neutral like 2nd gear is totally gone (broken band) and the trans doesn't slip at all, going into drive & reverse is firm and no matter the RPM, it stays engaged.
A couple things that trouble me;
- The fluid was dark and gritty. I doubt it had been changed in a LONG time. The radiator cap was OEM and the spark plugs & wires looked old and worn. Looking at the state of the vehicle, I wouldn't be surprised if that was the factory fluid in the trans.
- There's a rattling at certain RPM. It may just be the loose heat shield between the cat and trans that I couldn't get back into place or something worse...
- After driving vigorously, the auxiliary cooler and my in-line filter are barely warm like fluid isn't flowing through the cooler lines very well. My 1991's in-line filter gets so hot I can't touch it after normal driving.
