Kaidenshi
- February 9, 2020
- Location
- Georgia
- Powder Springs
- 1994 Explorer Eddie Bauer
- Callsign
- KF4YTR
Hi folks. I know the A4LD and its many issues and quirks has been covered to death in this community; I've read all of the posts that I think are relevant, but I haven't found a solution to my issue yet. I was hoping to get some insight.
So the 1994 EB 4x4 I posted about a few weeks ago has turned out to have a transmission issue. A few days after I got it, I noticed it was being sloppy in all the gears, hunting back and forth like the kickdown wasn't set right. I had already planned a full round of fluid and filter changes, including the transmission, so I went ahead and changed the fluid and filter and adjusted the bands, as well as the kickdown cable. I followed all the suggestions on this site and in the technical manual for the A4LD. After the above changes, I now had excellent, almost like-new performance in 2nd through OD, hot or cold. It was like a new truck. Except...when cold, 1st to 2nd was great and in line with the rest. Once I'd gone just a few miles, it would end up needing high revs (3500-4000rpm) to change into 2nd. From there, excellent performance in regular driving, but stop and go traffic was a pain due to the long 1st gear.
So this past weekend, I figured it wouldn't hurt to change the modulator valve since I'd be doing round two of fluid changes (engine oil and filter, transfer case, diffs) and I'd be under there anyway. After going to the trouble of taking off the cat, I removed the old modulator valve and found it was actually fairly new. Interestingly, the pin/rod was missing. I found the pin a few minutes later embedded in a layer of grease on the topside of the tranny, so I cleaned off the pin, put it in my new modulator (a twin to the one I took out, with the hex adjustment screw), reconnected vacuum, and put everything back together.
This time around, I only had 2nd gear. No 1st, and no upshifting from 2nd. I got back home and swapped back to the old modulator, again with the pin inserted correctly, and same thing. I put the new one back in and adjusted it a couple of turns CCW, and now I have shifting through all gears but only at very high revs (4000+). It shifts really, really hard too.
I'm at a loss; if the old modulator was missing its pin it shouldn't have been able to shift out of first, correct? And by putting in a new modulator with the pin correctly inserted, I should have 1st-2nd? And either way, swapping a modulator should have had no effect on 2nd-3rd and 3rd-OD, right? Fluid levels are good, I rechecked my band adjustments and they were correct. When I did the fluid and filter change, it looked like a new transmission on the inside; valve body was clean, magnet had very little material on it and what was there was very "silt" like, no chunks or pieces of metal.
One thing I've noticed that threw me off is what appears to be a 3/16" or 1/4" vacuum port on the extension housing, with no hose on it. It's coated in grime and appears to have been that way for years. I have no idea what that would connect to; does the governor require vacuum? If so, I have a spare port on the tree coming off the manifold that's currently plugged, could I use that to connect it? I have tried looking at photos of the A4LD and its extension housing online and I can't tell if that port serves any actual purpose.
Thanks for taking the time to read through all of that. I know it's a lot of info but I like to be thorough when trying to diagnose an issue. Worst case, I have a local transmission guy who comes highly recommended; I spoke with him about it and he thinks it's the wrong kind of modulator but without looking at the truck he is stumped on the sudden high gear issues. I can take it to him if necessary but I'd rather fix it myself if I can.
