A4LD slight shudder/slip? | Ford Explorer Forums
trooper8
Southern California
94 XLT
After slowing such as to round a corner in a neighborhood, step on the gas and the trans hesitates to engage slightly and then goes just fine. Other than this, everything works/shifts perfectly.
Shudder? It doesn't feel like a conventional AT slipping, but I guess that's what is technically may be. Is this the TC clutch?
Is a flush likely to help this? Likely to get worse? Is it rebuild time? Is there something an accomplished backyard mechanic can do to fix it?
Many thanks in advance. -Pat :us:
94 Exp 4.0L A4LD 2wd 170k bone stock
