zipichewco
- June 14, 2003
- phoenix AZ
- 96 xlt
4R55E Trans problem, shudder, slip
Hi;
I'm having a problem with our 96 Explorer transmission again, it was rebuilt 5yrs ago at 63k now has 121k. (Supposedly, a valvebody with all new solenoids was installed to fix an intermittent flashing O/D light I had afterwards)
Two weeks ago it would flash the O/D when putting it in park and waiting a while but no driveablility issues except some shudder sometimes.
Now the sequence goes like this: On the highway it begins to shudder and slip at 65 when the TC locks up, if I push the O/D button off it all seems ok. After coming off the freeway it seems to slip from 2-3, and will get in gear if I ease up on it.
Will set Code 756 solenoid b performance or stuck off, and once had a pending Code 761 solenoid c performance or stuck off. After it's parked I can startup and everything seems fine, no codes etc driving short distances around town. It seems to start slipping after it warms up.
I plan on dropping the pan, replacing the 6qt of fluid and maybe checking the valvebody torque 85 in/lb? And will be probably bringing it into a shop on monday, it's because of that work thing we all have to do.
A long time ago I rebuilt a C4 with a B&M kit. I'm willing to look at the valve body and put a shift kit in but don't know which way to go with it.
Any suggestions would be appreciated? I'm in the Phoenix area if anyone has any shops to recommend.
Thanks
Rich P.
96 Explorer 4wd 4r55e
rebuilt at 63k (intermediate band broke at anchor) now has 121k
Phoenix area
Hi;
Thanks
Rich P.
Phoenix area
