A4LD slips in O.Drive | Ford Explorer Forums
20yearford
Hopewell Junction, NY
1992 Ford Explorer
Happy Fathers day gentlemen.
I am new to this site, so here we go. I have a 1992 Ford Explorer rear wheel drive with the A4LD transmission that slips in and out of overdrive.
Need help, can't afford a rebuild.
Also check your fluid level. After a good warm up drive leave the truck running in park (P) and check the fluid level. There is a dipstick in the back of the engine bay behind the engine. If you notice your fluid is low or dirty or low and dirty a fluid/filter change isn't a bad idea and fairly easy to do. Along with the band adjustment you should be good to go. Make sure if you do a fluid change only replace the exact amount of fluid you take out not put the 10 quarts it actually holds unless of course you do a full flush the you would need to replace it all.
