97explorerltd
- April 26, 2008
At low speed stops the ABS kicks in and the pedal pulses. There are no codes set. After searching this forum it seems the rear abs sensor in the diff. is prone to failure so I unplugged the wire and the problem went away. Changed the sensor plugged the wire back in & problem still exists. Still no codes. Does anyone have any suggestions?
