abs and stability lights on | Ford Explorer Forums
explorerVzla
Venezuela
2006 Explorer EB V8
hi guys im having this problem with the lights they just turn on randomly but i dont feel any difference in the car anyhow here is a picture.
sorry for bad English and greetings from venezuela:thumbsup:
Uploaded with ImageShack.us
hi there.
It will probably be one of the ABS sensors, if front, then youy'll have to replace the whole hub/bearing assembly as the sensor is incorporated into it.
But first check the rear ABS rings located on the rear half shafts. They are 2 toothed rings that are very common to cracj and set the light off. Jack the car, crawl under and rotate the tire, and with a flashlight inspect each ring. If you see a crack, get a new one from Ford, they are thicker and better design than the original, cost is maybe $ 20 but it's a hassle to get to them.
PS: Your English is just fine, better than lots of people born here :)
thnx but this problem is very weird i have about 5 days without the lights coming on i checked the rings and they are fine
+1 on replacing the hubs - brace yourself it is costly.
If the problem is not a "visible" one, you need to get it read by the scanner, and a regular OBD2 will not do. It has to be ABS scanner. That will tell you which corner is a problem.
