Dawgpack
- January 29, 2012
- Bozeman, MT
- 1999 Explorer
For about the past 3-4 months my ABS light has been on. It stays off for random periods of time when I start driving, anywhere from 1-5 minutes usually. Around the same time my ABS started to intermittently come on while braking as well. At first it was when slamming on the brakes a little and it'd last maybe a couple seconds and go away for a few days. More recently it's started to become a bigger problem. It came on for a good 30 seconds of braking today when I was driving through my neighborhood. What the hell could be causing this?
Both front wheel bearings have been replaced by Firestone in the past 5000ish miles. I'm guessing my alignment is WAY off because in the last 8k miles, the inside of my front tires wore down to almost bald while the outsides still have a solid amount of tread. I'm not sure if that could cause an ABS problem. I'd be happy to give any other info if someone thinks it'd help. I'm gonna take it to Firestone tomorrow but just wondering if someone might have had this problem before.
Edit: I should probably also say that there's absolutely nothing on the road that should cause ABS to come one. Dry pavement, no gravel, nothing out of the ordinary.
