Abs light after hub job | Page 2 | Ford Explorer Forums
Well truthfully guys I went ahead got original ford motorcraft. We've had our fair share of aftermarket or 3rd party hubs fail, and we said screw it go with oem they'll last longer then finest Chinese.
I thought that I had scored big time when I found a motorcraft hub on amazon at a good price. When it arrived the plastic part that protected the sensor wire where it entered the hub was broken. So I sent it back for a replacement. The insulation on the new one's wire was cracked at almost the same place. Had to get a refund as there were no other motorcraft hubs left on amazon. I finally went with Timken and it has worked great since.
I don't do the hard offroading that a lot of you guys do, mine is just used mainly to get through the Chicagoland snow on the way to homedepot.
Hey guys I solved it. I was a idiot and didn't plug the harness in all the way. It was loose I pulled on it pop came unplugged. Took a look at the pins and plug. Plugged it back in gone.
Oh, I've never done anything like that before....😉
i have 04
lot of motorcraft fakes out there could be one or in parts bin too long when in doubt get money back
i have 04 and it had mid year change of Alternators old and correct was grey metal on back newer on car black steel back
but different plug wire
pretty sure these were the real deal just been on the shelf with the wires wrapped around the hub in the packages too long.
