Skydmark1
- December 1, 2006
- New Hampshire
- 2001 Mountaineer
Ok so, I guess this is a fairly common problem as far as ABS problems go. My ABS light is on and sometimes when I stop it pulses as if the ABS is kicking it. It doesn't stop nearly as well when this happens and I kinda freaked out the first time.
Here's the deal....I pulled the big fuse under the hood and the little fuse in the fuse panel (#14 I think) I don't care if the ABS doesn't work, but I really hate that light.....anyway to get the light to go out aside from pulling the dash apart and pulling the bulb?
Also, is it likely to be my rear sensor? I know this is common and an easy fix. Can I test it without putting the fuses back in?
thanks
thanks
