d16v149
- June 26, 2010
- Seattle WA
- 2000 Limited OHC-6
Last month in very deep snow twice I noted that if a front wheel started to spin significantly the ABS light would come on (I tested operation definitely no ABS when the light was on) if I shut off truck then restarted everything fine (no light and abs working) I mostly leave the knob in "AUTO" unless the situation is quite bad then I use "4 high". All good now but it will snow again some day - Any thoughts ??
