96Ag
- March 5, 2010
- Austin, TX
- 2003 XLT
First, I would like to say thank you to the forum. I learned how to replace the front and rear bearings on my wife's 2003 XLT and it worked great!
Second, I found the video series at http://www.youtube.com/watch?v=aieqpQjRqK8 and and used them as a guide to replace the ABS sensor on the rear pumpkin of the same vehicle. It did take two tries to get the right sensor, but eventually I got the right one.
Following the video I checked for continuity from the wires that came from the engine, on the positive side I was good, on the negative, no go. I also checked the old sensor and got no continuity while I did get continuity with the new. So my question is, what's the next step?
Is there a part in the engine compartment that needs to be replaced? Is the wire bad? I would appreciate any advice y'all could give.
Thanks,
Thanks,
