There are two on the front. One in the left bearing hub and one in the right bearing hub. On the front you can not buy the sensor seperate. It comes with the hub only.
The rear ABS sensor is located very close to the top of the middle of the "pumpkin"
It is the only electrical connection to the rear axle, so it would be easy to spot.
