BootyDo
- April 21, 2007
- Baltimore, MD
- 2006 Limited V8
Hi All,
Kindly requesting any help from anyone that may have any insight into a recent issue I'm having. Yesterday, driving to work, I notice my ABS & Traction Control lights came on, (along with the service wrench). I didn't notice anything differently in the driving conditions, so I restarted the car at the next red light. The ABS light stayed until I began moving - cleared right up. Then in about 5 seconds, the drive felt "funny" (like maybe I was slipping or something even though i was going about 5mph on a dry road), and the traction control starting blinking. Then both lights stayed on. Since then, I've restarted the car and driven about 4-5 times - each time experiencing the same issue above. But sometimes, it almost feels like something's going on when the first post-startup break push, (like slipping or something. Hard to describe).
Anyway, today I took a scanner and - even though there are no CEL on, found 3 "gray" codes:
C1236
U1900
B1681
After researching others' experience, i was under the impression one of the ABS rings or something broke. But that "C1236" has me thinking it's a speed sensor or something. Not sure what that is or how to fix it, but does anyone know if the codes are the result of a bad ABS ring, the same thing, or if the ABS/TRAC issues are the result of a bad speed sensor?
Any input would be GREATLY appreciated!
C1236
U1900
B1681
