Knavey
- July 16, 2020
- VALRICO
- 2017 Ford Explorer LTD
2017 Ford Explorer has different temperatures coming from the 4 front vents. The drivers side is about 10 degrees warmer than the passenger side. I have tried cycling all the vents, temperature controls, defroster, etc. Run them up and down with no change when I go back to maximum AC with a LO setpoint.
Found a post that said to push the climate control/defrost buttons at the same time, then climate control again. Tried that...heard the vents cycle, but still back to difference in temperature.
Looking for more ideas. Blend door actuator maybe? Is there a way to reset the door?
Also, does anyone have a good diagram that shows the different connections under the drivers side dashboard. Maybe the damper actuator needs rezeroed?
Thoughts?
Thoughts?
