Drivers side vents only blowing cold | Ford Explorer Forums - Serious Explorations
Hawk312
York, PA
2011 Explorer Limited
My 2011 Explorer with dual zone air is only blowing cold on the drivers side. The A/C seems to be working fine on both sides. When I turn it to heat (or "HI") hot air will blow out of the passenger side vents, but the air coming out of the drivers side vents will be cold. Not cold like the A/C is on, but like ambient temperature cold. I removed the glove box according to , and checked that actuator, but that doesn`t appear to be the issue. I am assuming there is a drivers side actuator? I was unable to find much information on the drivers side not working. Thanks.
Yeah there is a driver side actuator.
