team
- November 5, 2008
ok, got a few questions, but before I get blasted I have searched and read all the previous ac threads i could.
My system has a small leak and I put in about 1-2 cans a year and it works decent. Vehicle is a 1996 sport 4x4 4.0 ohv 168,000miles
Here are my questions
1. Does vacuuming down the system pull out any oil?
2. I see there is a seal kit and it looks like it has 10 o rings, where do all the o rings go? (do you have to unbolt any lines at the compressor, or just at the spring lock fittings)
3. I guess if i put on new o rings i need to get a new accumulator, if so, do they come with a new orifice or do you buy that separate?
4. Also, when you put in new refrig. can you just put it all in the low side with the can right side up? I saw on one of the help pages it was being put in on the high side upside down with the engine off, then put in on the low side right side up with the engine on.
5. If i put on a new accum. do I just drill a hole in the bottom, drain out the oil, measure, replace with the same amount and add extra 2oz. to this?
6. ALso, how do you put the oil in the best way? buy an injector, vacuum it down and put it in after a vacuum or what?
7. Is the orifice between a spring lock connector, or a cut out style?
That's all i can think of right now, obviously I am not the ac master so take it easy on me, but i want to try this so grace me with your knowledge. !
