asp84
- July 2, 2001
- Tempe, Arizona
- 1998 V8 AWD Mounty
Just hooked my AC up on my conversion car:
I have a: (Explorer with a 94 5.0L V8 in it)
- 1994 Explorer R-134A Accumulator (brand NEW)
-1994 Explorer R-134A Evaporator
-1991 R-12 Condensor (front of car)
-1994 R-134 mustang compresssor (panasonic rotary vane)
-1995 Mustang 5.0 Compressor lines
-Brand New clean Orifice tube
THe problem: My High Side Pressure is over 450 PSI!!!!! My Low side presseure is also abnormally high. Since I just today replaced my Accumulator and evaproator tube, soemthing else has to be the problem. NOTE: My old orifice tube did not have any crud on it, or show any the signs of black death.
Could a AC compressor that is goign out, cause this much pressure? or is it a clog in my system? I understand it is either my condensor or Air Compressor, i'd like to narrow my chances of buying the wrong part though.
Thanks,
Al
Note: he originally put in 2lbs of r-134, and then evacuated the system under vaccum pressure, and put in only 1.5Lbs to see if it would reduce pressure...........it didn't
Thanks,
Al
