nipits
- March 26, 2011
- Delaware, Ohio
- 2001 Explorer XLS
Alright HELP
I have a 2001 Explorer 4d 4wd Vin E 6cyl 4.0 SOHC
and I have been working on the air conditioning and I
have replaced the Orifice tube and it was extremely
dirty and i have metered both switchs and the high
pressure cut off switch is normally closed like it should be
and the other switch on the accumulator i metered and it
is normally open and goes closed when it has pressure on
the system so the clutch on the compressor will engage and
the switch is going closed like it should but the clutch on
the compressor is not engaging, I can apply 12 volts directly
to the clutch and it works perfectly.
The system seems to me that something is clogged but
i don't know what, if you try to put 134a in it it will take
some and the pressure will just build up and if i manually regulate
the compressor clutch so it will take the freon in it will build
pressure and when i engage the compressor manually the pressure
will go down and once i disengage the compressor the pressure
will build up again too high and the compressor will never engage
automatically like it should be doing and i have checked everything.
The only thing i haven't done is have a professional evacuate or vacuum
the system and refill it with freon but still i should at least i think be
able to get the compressor to engage the clutch even if i jumper
the switch on the air accumulator but i get nothing.
SO HELP PLEASE
THANKS
SO HELP PLEASE
THANKS
