colintrax
- July 16, 2009
- Georgia
- 97 XLT
You guys, you're throttle can only be opened with a cable attached to the gas pedal, the cable attached to the cruise control (which should be off if not being used) and the IAC (which can't speed the engine up to much)
Trust me, it's your foot hitting the gas pedal. I think the pedals are just a little to close together in the explorer, it's easy for your foot to hang off the edge and also hit the gas pedal.
The recall on the cruise control is just a fuse or something like that. Cruise control won't speed you up on purpose, it simply holds the speed unless you tell it otherwise. Even if you hit the buttons to speed up, it only changes 1mph at a time.
This thread needs to die, I don't even see how a floor mat could cause this considering how high up the gas pedal is, and the way it's designed.
