Add on Temperature Gauge anyone? | Page 2 | Ford Explorer Forums
Plugged mine in, warmed the truck up and fans come on at 94, and turn off at 92 degrees Celsius. I have an 82 degrees C thermostat, so that all seems to be a good combo. Stock T-stat is 92 degrees C, so the fans and thermostat would constantly be cycling on and off if I didn't fit the lower T-stat, or I'd have to have the thermos coming on at a higher temp, which I'm not comfortable with since I do some towing, so the cooler the better for me.
I took the plastic knee panel off below the steering wheel, to fully expose the obd2 connector. Then removed the connector from the metal tab and bent the tab up toward the dash just a bit. Put it all back together and now the ebrake is fully functional with the reader plugged in.
Up there for thinking!!! Nice work.
Everything deserves a write up I suppose:
