After Cluster Face Swap... | Ford Explorer Forums
Spartan
Sun Prairie WI
1996 XLT, 5.0 2WD
My gauges are off.
My fuel Gauge is just about right, so thats no issue. My battery gauge and Oil pressure are very suspect though. My Speedo appears correct. My Coolant temp seems way off too.
Is there ANY way of getting these things back to factory accurate? I'll post some pics in a bit when I get a chance.... also, the voltage gauge needle is way off when the truck is turned off.
the only thing you can do is pull the needles of, and replace them when the truck is running. what i did when i did my gauges was, run the truck for 5 mins, took a pic, then took everything apart. when i went to put it back together, did the same, run it for 5 mins, then looked at the pic, and put the needles back where they were.
That would do nothing. The face swap was about 6 months ago.
