aftermarket radio | Ford Explorer Forums
aftermarket radio
scubaboy
surrey uk
2006 xlt
i have installed a kenwood stereo and cant get the radio to work, any ideas
the cd works but no stations on the radio just hisdsing noise
help please
scubaboy
Check your antenna and grounds...
You have to push a LOT harder on the new antenna plugs compared to the larger old-style ones.
Your truck does not have a normal antenna plug. Did you get the antenna adapter with your new HU?
thanks i replaced the adaptor today and the radio now works fine
dont suppose you know where the vss cable is located to connect my sat nav to
could it be behind the radio as there are two spare plugs i assume one was for factory sat nave
thanks
alan
thanks
alan
Not I. I'm still using an external GPS. But there are a bunch of guys here who did that. If none of them reply in a day or so, You should make a new subject post.
