Well crap, I guess that won't work. The mass air sensor on the newer 5.0s flare out and bolt directly to the airbox - there is no flange to slide a filter onto.
However, since I really like the idea of having a K&N X-Stream filter, I'm not giving up.
There's two options that I'm looking at:
1. Replace my stock mass air sensor. That way I could get a bigger one for a little more flow. Since a mass air sensor for a 2000 Explorer doesn't have a mounting flange on the end to allow me to slip a cone filter on it, I'd have to get a mass air sensor for say a 97, but it still should otherwise fit just fine, or with little modifications. The only downside to this option is that it may end up being the most expensive.
2. I could order a True-Rev induction, and then instead of using the filter that comes with it, get a K&N X-Stream to use with it. (Seems kinda pointless maybe, but I'd WAY rather have a K&N than a.. S&B.. I mean I admit I haven't heard of them and they are probably just fine... but, would you rather buy a Ford or a Drof?)
Well, I'll be looking into it. As always, thanks in advance to anyone to has any info on the subject.
