Fordrulzz
- May 14, 2022
- Turner
- 2016 limited
Hi guys. I have a 2016 Explorer Limited 2.3L. A while back the air conditioning would fade in and out then stopped blowing cold air all together. A noise started shortly after and I found the ac clutch loose.... the bolt was actually broken. I put a new clutch, pulley, and coil on it and set the clearance. The compressor clutch works normally now with no noise but the ac still does not blow cold. I do not see any obvious leaks. Anyone have any ideas??
