Air conditioning problem maybe? | Ford Explorer Forums
imortlco
Cripple Creek, CO
2005 Ford Ranger V-6
2005 Ford Ranger V-6 5-Speed
A/C compressor cycles even though A/C is NOT selected, nor defrost, but instead full heat and through floor setting or vents or anything.
Is this normal, or what am I most likely looking at as bad?
THANKS!!!
As dumb as it is... normal.
It cycles in any mode except "Off", "Vent" (dash-only vents), and I think bi-level. Any other mode it starts cycling.
If you want to kill it completely, wire up a seperate switch inline with the compressor clutch coil connection.
THANK YOU!
I appreciate the answer.
