Air Conditioning | Ford Explorer Forums
Air Conditioning
hotrod69
Amarillo,Tx
1998 ford ranger 4x4 4.0
On my 1998 Ford Ranger trying to charge AC the Freon is blowing out of the relief valve. Any suggestions?
i have a 2002 ford explorer do i have to remove a/c compressor to replace my a/c lines ?
Your high side pressures are too much.
Assuming the Rangers utilize a fan clutch and not an electric fan.
Need to put a gauge set on the low and high side ports.
May have a clogged orifice tube (which means compressor is starting to fail) or an issue with the condenser or high side hose being blocked/clogged.
Need to verify your pressures first.
