Your high side pressures are too much.
Assuming the Rangers utilize a fan clutch and not an electric fan.
Need to put a gauge set on the low and high side ports.
May have a clogged orifice tube (which means compressor is starting to fail) or an issue with the condenser or high side hose being blocked/clogged.
Need to verify your pressures first.
