treats54
- December 5, 2010
- Heathsville, VA
- 2004 xlt
2004 Explorer
I had a problem with the blend door. Went to heatertreater.net and purchased a kit. I replaced the door first, turns out it was just the motor(would have been much easier to start with the motor first!) Now after putting it all back together I have two new problems that I hope are related.
1) The air flow will not change where it blows out. It is stuck on the floor and will not move to dash or defrost. When I turn the dial, I can see the small the small arm on the passenger side of the dial interface moving back and forth.
2) There is now a squeal coming from under the hood. It almost sounds like the alternator pulley type of squeal, but it is a little more chirping sounding. And it seems to be coming from inside the air-box located right above the engine.
Neither of these problems existed before last weekend. Any input will be appreciated.
