Air in calipers | Ford Explorer Forums
Air in calipers
coolgolf252
Durham, NC
93 eddie bauer 4x4
when i replace my caliper on the drives side, it bleeds fine with the tube and bottle trick. my passenager side still has air in it after bleeding it a few times. does anybody have any suggestions. thanks
[Posts extracted from your Wanted thread]
Perhaps the caliper needs to be replaced -- maybe the seals have thrown in the towel and said 'mah gawd, i quit'.
Are you getting the same pressure of fluid out of passenger side when you crack the bleeder open? If not, you may have bad caliper or collapsed line. Also, have you tried to drip bleed just the passenger side?
