air noise and door adjustment | Ford Explorer Forums
MikeTEC
Central Texas
2004 Mountaineer 4.6L
Does anyone know the correct procedure for door adjustment to prevent outside wind noise at highway speeds? Best I can tell leakage is at the upper front around the driver side door. Hope to do some minor adjustments and not have to replace the seal on my 96....Thanks for your help! Mike
Pretty easy. If I am not mistaken it takes a Torex size 45. Just open the door crack the door striker ( the part on the beam not the door its self ) Crack those bolts loose. Crack I said , not too loose cause then you'll be all day trying to re-align it. Take a hammer and tap the striker in just a hair. Too much you'll end up with door pop.
