hafcanadian
- October 18, 2013
- Location
- Oregon
- Oregon
- 1997 Ford Explorer Ltd.
Our '97 Explorer Limited developed a rattle several years ago. It only did it in warm, dry weather. Our local mechanic finally heard it, after several rides trying to get it to do it (that never happens, right?). He gave the rig back to me, no charge for his time, and said he thought it was the air ride level sensor device behind the driver's front wheel.
Today I finally got around to removing the wheel so I could see better what he was referring to. Yes, the device "rattles" from where an apparent rod meets a tube. But it's inside a protective bellows-like sleeve that's fastened top and bottom with special crimped clamps I dare not try to remove. I am amazed that the minimalist rattling heard at the device is amplified into the passenger compartment and is even felt in the steering wheel. But apparently that's so.
I could see no way to stop the annoying noise other than to use a wire tie around a nearby brake tube mount to see if it will mitigate the "slop" between the rod and tube. Of course "rod and tube" are just assumptions on my part since I can't remove the rubber sleeve surrounding those components. I've yet to test drive my "fix", and am wondering if anyone else here has dealt with this issue. Please advise if the wire tie might cause issues; I did not tighten it, but rather used it to merely move the upper sensor box enough to take up a smidge of its slop... about 1/16th inch... and hopefully not cause any binding rod into tube. Any thoughts or experience would be appreciated.
