Air vents problem | Ford Explorer Forums
Air vents problem
Digger196
Winston-Salem, NC
98 Cherokee
I knowtist today that on the driver side that there is very little air coming out of them. There's tons coming from the pass. side.
The vents are not closed so don't ask if they are.
How do i fix this?
Anyone else have this problem?
if you have airflow coming out of the pass side on the panel setting then maybe your driver vent is broken in the "off" position???
no it's not. the vents are open. it's l;ike the tube came off or something
I've got the same problem. It's not locked shut but still nothing's coming out. Any ideas why?
Do a search I know this has been mentioned before.
I think it happends when the feeder tube gets mis-aligned or something blocks it. It's a PITA to fix,
Try closing your other vent and see if you get ANYTHING out the the drivers side. In the article I found, there was something coming out, just low pressure.
